purlin size and spacing spacing for floor
  • purlin size and spacing spacing for floor
    I built a steel building that is tall and I am wanting to add a second floor in it for a sort of office for me. It is going to be 10 feet wide by 30 feet long. Nothing fancy just a desk, and a warm clean space to work on stuff. Maybe a small table on one end for poker night with the buddies.
    Anyway right now I have 10" C purlins ran across the length of the shop that I am going to build the floor on. The purlins are parallel and 10 feet apart. I am needing to weld some more purlins in there to span this 10' gap and to attach the floor to. I am thinking of using 3/4" plywood for the floor and spacing the purlins 2' apart. Is this sufficient? What size of purlins are required to span this 10'? 3", 4" ?
    I figure the maximum weight up there spread over the whole area will be 2000 lbs. That would be 6 guys at 200lbs plus 800 lbs of desk, furniture, etc. I have been welding for about 15 years and am confident in my welding ability, I am just not really sure what size material I need for this. Obviously I don't want it to collapse, but I also don't want to spend more on materials than I need to.
    I don’t have any information on purlins, but here are a couple charts for I-beams .
    Dynasty 300 DX Tig Runner
    Survey says!!!!!!!!!!!!
    Blue is prettier than purple or yeller
      I have never used purlins for a floor, but have built many thousands of SF of steel stud floors. The smallest we would use were 10". Most were 12" at 24" OC. The tens were 16"OC, IIRC. They were also capped with 3" of lightweight concrete instead of plywood. If it were mine, I'd stick with 10" on 2' centers to be safe. You will beed to brace then laterally at mid span or on 4' centers. On 10' long, mid point would work. Also, any point where a purlin will rest on a wall or frame member below will need a stiffener. You put it across the open side and weld top and bottom. It keeps the purlin from curling under load. My two cents, anyway.
      Don
      Go Spurs Go!!!!!!
        http://www.flexospan.com/products_cees1.htm has a load table for cee and zee channel purlins
          i don't know much about the steel but tongue and groove plywood subfloor deck generally goes on joists spaced 16 inch centers minimum as far as the wood framing end of it it'd tend to sag on 2 ft centers
          surff
            Ok, 16" centers. That is no problem. 3/4" plywood? USMCPOP, those tables are exactly what I was looking for, but I am not sure I am reading them correct. For example if I were to use 6" purlin, with 2.5" flange, 14 gauge, on a 10 foot bay the chart says 331. What does this 331 mean? Total weight it can carry evenly distributed over the 10', weight per foot?
              Yeah, I had the same reaction. No units given whatsoever! I expect it's total weight in pounds evenly distributed over the span, but no way to know offhand. However, it does at least give you a way to judge relative strength from one size to another. It also made me wonder how your 30 ft. span of 10" channel was supported.
              Wish I had my engineering resource with me now. My older son was studying mechanical engineering, but went off to Iraq with the Marines. Lost him a year ago tomorrow.
                Sorry to hear of your loss. If he was anything like you he must have been a fine young man. You must be very proud.
                Semper Fi
                Dennis
                Dennis
                Thermal Arc 185-TSW
                Millermatic Challenger 172
                VictorO/A
                Atlas Craftsman 12 by 24 Lathe
                Esab PCM-875
                Wholesale Tool Mill-Drill
                  usmc pop
                  you're both in my prayers semper -fi
                    i do this for a living
                    don't wing it get a structual eng. won't be too expensive
