Looking for guidelines to estimate various fabricating jobs. Any books or software anyone reccomends?
Estimates
My shop rate is $30 and the mobile is $50 with a 1 hour minimum.I think the shop rate is gonna go up a little.
Now let me ask you this,are you charging extra for aluminum?how much?
To keep this on topic and answer the original question,I figure out material costs,figure my time multiplied by my rate + any weres from 10-25% on top of that depending on how comfortable i am with my time estimate.So far i have been really close on the time thing.I don't mark up materials and deal almost exclusivly with one of the cheapest steel yards in the state and pass on the savings to the customer.
I don't do aluminum. YET, but I think a little higher estimate would be in order. At least I would expect to pay more myself. The reason I asked is that I heard a comment from a guy that works for a big company. They were getting bids for from fabricating, about a $5000 job, and all bids came within $500 of each other. Seems they were all reading from the same book or something. Thanks for all the response so far.
Have you inventoried your property today?
Hello, I created job estimate sheets that I use for each job. The sheets contain every aspect for a finish job.
Hours
1) Design & Layout
2) Saw cutting
3) Drilling
4) Fixturing
5) Fitting & Tacking
6) Welding
7) Grinding
8) Machining
9) Stress Relieving
10) Sand blasting
11) Cleaning & Painting
Total Hours x's rate
I figure out hours for job x rate + materials + vended materials
I also add say % to materials and vended parts.
Rates I charge depend on complexity of job.
Tool Welding 55.00 Hour
Sheet metal guarding or ducting 55.00
Precision Brazing 55.00
Production welding per pc. part to be 55.00 or better
Fabrication ( simple ) 35.00 - 55.00
Also definitely work your vendors for the best prices you can get. I have made calls to all of mine working them again and again and all I'm goona say is they can and will move your prices to keep your business.
J P Streets Welding LLC
shop and field rate is $55/hr (can). extra for hard surfacing. minimum is 2 hrs. its not cut and dry about materials......depends on quantity (percent added i mean). i usually add 30 %. I have a breakdown list like jp streets. your rate shouldnt be so concerned with what everyone else charges. youre rate should reflect your operating costs, ie; consumables, hrly rate for each machinery, insurances, workmans comp...etc
Yup, thats what we get $55- residential 2 hour min.
$65- commercial 2 hour min
I get extra for emergencey repairs (Snow Plows) they run about $125- and again there is a 2 hour min what this is for is to break away from one job to respond to the emergencey, or in the event it is after hours.
Shop work runs about $45- an hour
Materail mark up is %33 that includes all cumsumables.
No matteer how you bill some will pay you no questions, others will hem and haw and complain sometimes you just cant win.
Good Luck
Bernie
Tyng Ent
Our field rates are:
In California- Welders $75/hr straight time, $100 overtime
Welders helpers $53 st, $73 ot
Other states- Pipe Welders $65 st, $82 ot
Helpers $26 to $40 st, $34 to $58 ot
Structural Welders $57 st, $72 ot
4 hr minimum
.40/mile travel, both ways
rate + gas & extra consumables for any TIG welding
Rate includes a certified welder, welding rig with machine, torch & hand tools.
Equipment such as fork lift ect. I bill at the rental rate + 15%
Material I bill at cost + 15 to 20%.
JTMcC.
Whatever you decide to bill don't forget the little guy that can be a pain in the butt and not know what he realy wants.
On the other hand also remember the guy (like me in the past before I had a welder). that brings somethig simple in and says 'can you weld this together for $20-25 bucks' In my last case it was an exhaust pipe I had cut off a precat that I had knocked the stuff out of. I had indexed it and everything for the guy ahead of time. $20 and 5 minutes later both of us were happy.
Yeh your right, when I get a local guy who needs a little weld I'll ask him what its worth. The other day retired guy came in with a shute from chipper all cracked, I welded it and said see ya later buddy.
But usually 99.9% I'm dealing with area businesses not the general public.Jerry Streets
