Here is the drawing for the second part of our machine.As you will see, this part was made from a peice of 5"X 6.7lbs channel. There should be no problem using a peice of 4" X 5.4 lbs channel , or even a heavier 4" channel instead. Important: At this point, I recommend that you guys please wait until I get these drawings posted, and start stepping you through the fabrication of this machine. The reason being is because there are a few important steps to follow so that you don ' t have a problem with the pivot point being off.
Brake drawing # 2
Brake drawing # 2
Last edited by Dan; 10-01-2002, 05:36 AM.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
HH 125 EZ - impressive little fluxcore only unitTags: None
