I'm a newby with an old Lincoln 230V buzz box that I got at a farm auction for $35 and a new Lincoln Power MIG 200. Here is a recent creation to snip off 3-4" trees that are planted to close.
http://www.tractorbynet.com/forumfil...ilt%20stop.jpg This show a stop I had to weld under the bottom pin so the snipper wouldn't rotate too far ( analagous to dumping the bucket) and pull the hydraulic lines apart.
I need something to cut 45 degree angles. For thin stock I brought a14" abrasive Milwaukee chop saw. This has been a big disappointment; the vise pivots in the middle so when you angle it to 45 degrees you have to unbolt it and set it up in a new bolt hole either forward or backward so the stock is under the wheel .
Makita makes a 12"carbide model LC1230 that is a favorite of those who are using steel stud in home construction
http://www.makita.com/Tools_Item_View.asp?id=210 The vise pivots for 45 degree cut right next to the blade plus a lever on the left side of the machine tightens the vise- no need to slide the vise assembly to a new location. Also I've seen carbide steel cutting blades on a "Skil" saw set up for a more free-handed approach
A band saw that will cut 45 degree angle AND wide enough to handle wider stock is $2500 http://www.ellissaw.com/bandsaws/bandsaws.html I saw a cheap chinese swivel head that is $400 but I doubt the quality.http://www.grizzly.com/catalog/pages...?&site=grizzly
I need some guidance re these tools, are there reasonable used machine available etc?
