Posting A picture
  • Posting A picture
    I finally got my pictures developed, how do I get them here ? I have a scanner and windows 98. You have to keep this computer stuff simple for me.
    First you need to scan picture in a low resolution mode so it will fit th reply page. Name it something you can remember, cart1, for instance and save to aan appropriate folder on your PC. When you are ready to post it, click on the browse button at the bottom of the reply window and select the correct file. You can also paste the location in the body of the reply if you have more than 1 picture to display. Your scanner manual will guide you through the scanning process,
      Farmer,
      Read through the FAQs (see menu above).
      Do a search for posting images.
      I'd use Windows Explorer: Create a folder.....say... welding and subfolders if needed.
      Choose a format like JPEG or others that are acceptable.
      Scan 'em in, name them something you will recognize.
      Make sure each image is less than 103kb.
      Lighten, crop or other as needed.
      You said short and simple.
      Dave
        posting
        if you already have a picture stored on your computor how do you change the resolution to post the picture. I tried to post a picture and it said it was to large.
        doin the best I can with what I got
          Skinner, Any good image program should let you reduce your pictures. I like paint shop pro. You can either reduce the picture or you can just cut and paste into a new image. Just cut out what you want and paste it.
          Farmer, digital cameras are really cheap these days. You could get a good one and make transfering you pictures quick and easy. Think of the money you would save in film and developing. I would use the regular camera when you want a hard copy of the picture and use the digital camera for internet pics.
          Art is dangerous!
          www.PiedmontIronworks.com
            test post
            i am trying to learn how to post pics.
              posting pictures
              FARMER,
              i had some problems posting pics,until i
              found out they were in the wrong file.
              after i put them in a jpeg file, i had no
              problems.
              enclosed is a milling picture cutting
              male splines on a shaft.
              wlbrown
                Posting
                Have the teenage son instructing me hope it works
                  windows xp
                  does anyone have xp I have pics in the my pictures file and it says that they are in jpeg format but I cant figure out how to change the resolution, when i try to upload them it tells me that they are to large
                    Skinner,
                    I don't have XP but open an image, try properties under file menu in whatever program you are viewing the images. If resolution is shown to be 300 pixels change to 250 etc., save and check file size. You are looking not to exceed 103kb. Resizing the image also changes the file size, which sometimes automatically changes when you change the resolution.
                    If resolution is not shown in properties try checking Help/index/resolution.
                    Dave
                      dave
                      I tried what you recomended the only thing it will let me change is the size but in order to get it small enough you dont have any picture left.. I cant seem to find out how just to change the resolution. I think I am just about ready to give up! I could have finished half of the unfinished projects that I have started in the time I have spent trying to figure this out
                        skinner,
                        Don't give up.
                        Try a search of this site. This has been discussed numerous times. Several links have been given for software. Some is even free and downloadable. Some software even has options such as"optimizing" which automatically lowers the resolution.
                        Dave
                          tryagain
                          if this works i will start taking pics of my projects
                            Almost There
                            Had the son give me a few pointers on this computer stuff, I do not spend enough time working with the programs to learn how to work them. I finally got a picture to post but can not figure how to get it to enlarge so it can be seen more readily.
                            The V ditcher is used to run a small ditch thru low spots in the field to a drain, so excess surface water can be drained. I began to design one, went to the scrap yard for material and Voila !! What is sitting on the top of the heap, complete with hydraulic cylinder. Picked it up for $40 Cdn. I put about 1 hour of refit and there it is.
                              farmer
                              sounds like you and I need to change programs or something my computor will not let me size mine down.
