So I'm starting to hook up my new toy the Millermatic 200
got the gas plumbed -- two welders from on tank... pics will follow someday
wiring done and a new Miller M25 torch in place... I remove the nozzle and tip and feed the wire thru the guides and into the tube... I adjust the tension on the wire feed motor till it will pull wire smoothly and it feeds thru the tube toward the torch... after the wire comes out I slide the tip over the wire and screw it into the torch and reattach the nozzle. try the wire feed again and the wire jams at the mouth of the torch (the welder end)... dang-bang @%$$%^&*$ wire
... take it all apart.. cut out the bad.. pull out the wire and start over... picture this about a thousand times...
I can't seem to find a setting on the wire tension that will keep this from happening and I swear it only happens with the tip in place... it's a .035 tip and .035 wire but the wore feels 'tight' in the tip... it slides but there is the slightest bit of friction... is that normal... I don't feel it in my Hobart Handler tip in a Tweco gun... any suggestions.. ???
I will add that this is an old 44# spool of wire ... discolored but I reeled off the rusty wire... would this make a difference also ???
help oh GMAW gurus !!!!!!
john
john
