Rock,
the guys on the Products forum say "Ask Rock, he knows EVERYTHING"
so here goes... hope you can help...
I just rolled a millermatic 200 off my buddies truck and into my garage... bought it used ( of course) for $200 bucks... it will weld with stick leads attached so I know that parts works..
the wire torch is broken and the switch is missing so I can't try that yet... I tried jumping out the trigger lead to see if the wire drive motor works and I hear the relay click in but there is no motor movement...
I removed the drive motor and pulled the gear reduction out... it moves freely but the drive shaft on the dc motor will not turn... so I'm assuming my problem is inside that black round case... before I start hammering on it... have you got any suggestions ?? (seriously...I wouldn't hammer on it) I see it's dc and I don't know jack about dc motors... is it fixable ??? or can you see it from there...
I'm not familiar with this welder at all and after I got the cover off I knew I'd better ask for help... I can screw up things at warp speed !!
can you give me some trouble shooting help, advice.. ideas ?? and also a good source for a gun and lead that's affordable..
thanks
john
thanks
john
