Cutoff Wheels
  • Cutoff Wheels
    Rocky D,
    Thanks!
    It's like I've discovered a new tool!
    I have numerous ways to cut things and have been using angle grinders for many years to grind and wire brush, but you can't really do a very good job of "cutting" with 3/16" or 1/4" abrasive wheels.
    Your post on 10-04-02 got me to thinking. For certain things the thin disks really work and FAST!
    Thanks.
    Dave
    I use mine more than my torch, now.
      Is it time to shift those worn cutoff wheels to 4" grinder?
        It's strange, but they don't work as good on a 4" grinder. They wear too fast, but on a 5" grinder, they do just fine.... and I speak of the .040" wheels not the 1/8".
          What RPM does your 5" grinder spin the disc? My 4.5" rt-angle grinder rotates disc at 10,000 RPM.
            Mine turns at 11, 000...seems to make a difference.
              Originally posted by russell
              Edge speed increases with diameter,so that at the same rpm the 5" would still be traveling faster at the edge than the 4" or 4 1/2".......and I would think that the extra velocity would add to the beam strength and aggressiveness of the disc....which I think should make it cut faster with more metal removed per disc.....of course I have been wrong before......
              russell
              Let me pose a question....First off, Russell, let me say I think you're right...Now...a 5" disk traveling at 11,000RPM at the parimeter, is traveling at how many RPMs at the center?
                14399 ft per minute or 163mph @ the edge on a 5" disk @ 11k rpm and 10742 ft per minute or 122 mph @ the edge for a 4" wheel on a 10k rpm grinder for a difference of 3926 ft per minute or 41 [email protected] the cutting edge.
                ~Nate~
                NCLS LLC.~ Big Nate's Plowing
                ~~~~~~ I like a nice piece of SCRAP~~~~~~
                NCLS LLC- SMR Division (Scrap Metal Recycling)
                I FOUND A CHEAP TIG :~D
                  I'm with Dave, I discovered a new tool. A friend told me about those .045 wheels about a year or more ago. And I bet I've used 2-3 dozen since then. I love them. Thick/thin/big/small ... nothing I can't tear up quickly now It's quick, precise, doesn't get stuff all HOT like using the torch and incredibly versatile. can't say enough good things about them.
                  - jack
                    any body use the 1 mm thick metabo 4 1/2" discs? those are quicker then a torch on 1/8" and 1/4"
                    and yes the numbers are pretty impressive considering a 21" lawnmower blade @ 3000 rpm travels @ 187 mph
                    ~Nate~
                      Originally posted by aweaver
                      Rocky D's trick question: "Let me pose a question....First off, Russell, let me say I think you're right...Now...a 5" disk traveling at 11,000RPM at the parimeter, is traveling at how many RPMs at the center? "
                      Answer: 11,000RPM. RPMs are the same regardless of where on the rotating object they are measured.
                      Don't know if he meant it to be a trick question......
                      Big Nate's numbers check out, otherwise.
                      Yeah, you got it...it was a trick question. RPM's are the same...IPM's are different.
                      I discovered that when I had to program an Orbital Tube Welder.
                        IPM?
                        Ok Rocky D,how many IPM at the exact center.That should keep you busy for a while.
                          Re: IPM?
                          Yeah....right
                            a 5/8" shaft spinning @ 10000 rpm makes for 19635 ipm @ the edge or 18 mph
