Anyone have opinions on the following?
Is there a disadvantage in welding capability in going to a unit like a Millermatic 210 or Lincoln 200 vs. a Miller/Hobart/Lincoln 175 ? I need to be able to work at least with 24 ga. thru 1/4". In what way would a TIG unit fall behind for general use in this range?
How critical is a variable voltage control (like on Miller 175) vs. a 4 to 7 position tap? Do any larger units have continuously variable controls?
I have been told that Lincoln has a better MIG gun and the consumables for it are cheaper. Also has a flux shield for the tip when flux core welding and Miller does not? Any big deal?
Have been told that Miller 175 has a heavier transformer, better wire feed mechanism and better components than a Hobart 175...how true? Why is Miller 175 20 lbs. heavier than comparable Lincoln?
Where does Century fit into the lineup.?..seems to be found more in wholesale outlets than local suppliers....why? Units seem to have good specs.
I have been told that solar powered instant darkening shields do not last as long as battery powered ones..true? I have only used flip up shields but the advantage of instant darkening is obvious...how much do you need to spend for a decent one? Anything to stay away from?
I obviously have more questions than experience...any help would be appreciated.
