Weldit wire and contact tips
  • Weldit wire and contact tips
    I switched from .030 flux core wire and tip to a .035 flux core wire and tip and although I used Weldit (Hobart) wire and tips, the wire was an unusually tight fit in the new contact tip. So much so that I had to use a welding tip cleaner to slightly enlarge the new contact tip so the wire would feed. I carefully filed the end of the new wire but it was too tight to feed. I double checked the size and marking on the new contact tip and even tried a couple other tips in the package but the fit was the same. Is this unusual or a common problem? I figured I was ok because I was using Weldit wire and Weldit contact tips and the tips were labled for Miller or Hobart. What do you guys think?
    tip to small?
    i have also run into that same problem and now when i get new tips i have a drill bit i use and reem them all out to about .036-.038 and found out this works just great. no more wire sticking in the contact tip.
    fire bug
      same thing happend to me with the included .30 flux wire and tips that came with my hobart 135, all i did was forced it through with the wire and it came out fine, it shaved some little copper bits from the inside and now its come out just fine
        A thought that makes you go Mmmmm...
        I read in the SMAW book by Miller that some contact tips have a curved path for the wire to travel to increase amperage transferance. Those type of tips you could not see thru when held up to the light. I wonder how they drill a curved hole?
        So far I have gone thru about 3 lbs of wire and the tip seems to work just fine on my hh175.
