cant controll Amps
  • cant controll Amps
    I have a Hobart Simplified Welder Model GW-222 Serial # AAW-11772 50% Duty Cycle Specs. 2208A Amps 200 Volts 25. I would like to know if I can get a manual because I can't seem to control the amperage levels. Thanks for your help. Larry
    I am not sure if there is still a manual in existance, But try looking at the rheostate and see if it is open. also there should be a polarity switch on the front and I have heard of this arcing and not letting the voltage through to the field windings. Call our tech number at 1-800-332-3281 and see if they can help with a manual.
    dave Evans
      I also need a Manuel if possible
