I'm hoping to purchase a new air compressor by aprox May or so when we move to a new house. I need a much larger unit than my old worn out Craftsman model that's over 18 years old.
I plan to use it with a blast cabinet, HVLP painting, grinders, cutoff tools, drills, etc. I'm looking to buy a true 5 hp minimum with an 80 gallon tank. I'd really like a 7.5 hp, but that's my dilema...might be out of my financial budget...like to stay at $2000 if possible.
Our local TSC has Ingersoll Rand units, but after looking at them, there not as impressive as I originally thought.
I found a company in Ohio that custom builds compressors and they have good pricing and excellent heavy duty compressor packages. Here's their link.
http://www.eatoncompressor.com
Look under the single phase section.
I am very interested in buying from them as they were quite helpful over the phone, but I also realize having it serviced would be an easier job if it was bought locally.
I found two local air compressor sales/maintence companies. Here is what they had to offer.
company #1.
Saylor-Beall brand, 5 hp, 80 gallon vert tank, 17.3 cfm @ 175 psi, $1775
Saylor-Beall brand, 7.5 hp, 80 gallon horizontal tank, 26.2 cfm @ 175 psi, $2935
The salesman claims Saylor-Beall won't sell a 7.5 hp vert tank in an 80 gallon as they feel it's too top heavy...would have to go up to a 120 gallon vert tank for $300-400 more.
company #2
Devair (formerly Devilbiss), 5 hp, 80 gallon tank, $1950
They didn't give a firm quote on the 7.5 hp, but felt it was approx $2500 or so.
Eaton compressor sells their 5 hp, 80 gallon vert compressor for $1275 plus $180 for shipping...$1455 delivered total. 17 cfm @ 175 psi and a pump rpm of 800 rpm. This pump is a verticle two cylinder.
Eatons 7.5 hp 80 gallon model sells for $1780 plus $180 shipping for a delivered total of $1960. This one has 26 cfm @ 175 psi and a pump speed of 600 rpm. This pump is a V4 cylinder arrangement.
TIP tools in Ohio sells both Quincy & Champion compressors. While their similar, they run at higher pump speeds and don't seem to have as many options built into them as the Eaton deals.
Now, I have so many choices, but I guess the question is, would you feel safe buying from a company not close to you? Would you feel OK buying from Eaton? I know that many times things are cheaper for a reason...now what is it in this case. From what I can tell, Eaton is a manufacturer/parts assembler company, so your buying from a source, not a middle man/distributor.
I need to take some time to slip into the two local compressor supply houses.
Any thougths or suggestions?
I fully intend to buy as big of a machine as my budget allows. In the past, I bought too small of welders and regretted that decision till I finally looked at the purchase of a larger unit as a long term investment. I also want a large enough machine that I'm not beating it to death like my current/old compressor...need it to last a long, long time.
company #1.
company #2
