Different 110/220 plug types with pics
  • Different 110/220 plug types with pics
    Hey guys I was doing some research on the type of plugs on a 220 volt welder and I came across this site with pics of the different types of plugs. I thought it might help someone here sometime in the future?
    Do they not make the 230/240 volt plugs that have curved prongs anymore? My grandpa has an old stick mchine that has a plug like that, and I've never seen another.
    Lean Mean TIGing Machine!
    Lincoln Squarewave 175
      Describe better what you mean by "curved" prongs. Is it like the grounding prong on the NEMA 10-30R in the above link?
        Similar, but no square angles. It's round as in a circle would be, the prongs are as if you cut a little hunk out of a circle. I can't really think of a good way to explain what I'm talking about without a pic. All three progs are shaped this way and if you were to take a connect the dots aproach, could draw a line between the prongs and get a circle.
          those plugs are called " twist loc"they come in all voltages up to 600 and up to 30 amps. In single phase and three phase . Each combination has a unique configuration that prevents incorrect connections . search the hubbel electric site for a chart. They are industrial light duty . The heavy duty units are the "arc tite" style conectors that can cost more than a welder. Terry
            Thanks! I don't really need one, i was just wondering why you don't see them often, now I know.
              220 volt plug & outlet
              When I started investigating getting a welder and after deciding on a 220 volt powered one, I first had to run a 220 volt service to the garage. No use getting the welder without a place to plug it in. I had a difficult time finding what the outlet configuration was for the 220 volt welders. There are numbers for the plugs and outlets in the owners manuals, but I wanted to see some better grapics to make sure what to buy. I finally found a Hobart welder out of the box at a farm store and got to see a plug.
              So for those newbes and want-a-bes, here is a picture.
              Jim-bee
