Hi guys,
Ive been lurking for a bit, and finally registered. I recently bought a Hobart stickmate and am looking to make an extension cord for it. Im looking at a run of about 80 feet. I know its far, but listen to my set-up.
Instead of using a currently unused range circut at the house (we have a gas range but the house was wired for an electric one - #10 AL wire) i just put a recessed plug in about 1 foot below my breaker box. I used a 50 amp 2 pole breaker and #6 wire. So that is what I have right now.
From there i want to go 80 feet.
At max output the welder is going to draw about 50 amps. My question is this: What size cable should i use? Whats the minimum, whats sufficient, and whats overkill? I was thinking about #8, but i am not sure, since i am not an electrician. Keep in mind that i will be plugging it in very close to the breaker box, so its not like the outlet is already 100 feet away and i want to connect another 80 feet to that. I know i probably will rarely turn this thing up all the way, but i want to just know i could and not think twice about it.
Some of you might think this is nuts, but this is how is has to be. The welder will also see some use at my dads ranch, for which i will be making a similar outlet right off the breaker box.
Sorry for the long winded post - it really is just a simple question.
-Chris
-Chris
