OK guys I got in on the HF bandsaw deal...I could'nt resist, but now I have two questions about the saw. Ok first question...the instructions talk about tensioning the drive belt on the HF bandsaw first buy tightening the adjusting screw until you get the right tension...I got that fine, but I cannot find where they are talking about tightening the locknut....where is the locknut? The label in the picture in the instructions points to one of the bolts on the pulley cover which is wrong correct? I thought you just tighten up the two bolts that hold the motor bracket to the base of the unit? am I correct?
Ok second question? When ordering new blades at Enco what model saw do I specify? I saw someone else mention Morse...is that the one I should use? I came up with this blade below...is it the correct one?
Bandsaw Blade at Enco Model #371-0404
