Gas cylinder sizes
  • Gas cylinder sizes
    I found a site that may help those trying to buy gas, the question always comes down to the tank size and capacity. This site has an interactive gizmo that shows the tank sizes available for the different types of gases. Not all suppliers will stock all the sizes and may even have some not listed, remember this isn't put forth as the end all of tank sizes, just some info.
    Cylinder sizes
    Thanks Paychk
    Happy & Safe Welding.......Scott
    HH135
    Miller Auto Arc XLT 270
      Anytime
        Here's another one with a little different info:
          Appreciate the added info!
            This is another reference for bottle sizes I used also....... Bottle Sizes Hope this helps also. What size bottle do you have......? Jim
            MM251.......................Powermax600
            Lincoln Weld-Pak 100
              i have a 350cu/f bottle. 94 bucks to fill. for argon/co2 mix
              jiMMy
              Newbie to welding
                Good stuff on the gas bottles. It answers questions that I am not yet smart enough to ask.
                Thanks,
                Gary
                  rws
                  that link is from my local dealer good store great guys and great service
                  Hobart Handler 140
                  Lincoln Precision TIG 185
                  Harris O/A
                    I tried a 250 or 300 cu ft cylinder on mm251, and in my opinon it made the welder feel unsteady when rolling it outside. The dealer took it back, canceled the lease, and let me buy a pair of 125s.
                    It's not always economics. With the two cylinders I don't feel the need to replace the cylinder when its down to 500 psi so I won't run out in the middle of a project. I run it empty and refill at my convienence.
                      That is good he let you switch over like that. I have a 300CF bottle on my 251 and it seems to be pretty stable. Although I use it on a smooth shop floor and I don't wheel it around very far.
                      I was wondering about turning in an empty bottle. Should you leave a little gas in it? Someone told me to do that once. I can't remember why. duh. ..... Jim
                        Photo found on Web
                          500psi is a lot of gas, 80+cf bottles. i ran one of my 80cf down to 0psi, and it still was putting out gas.
                          97 s-10 vortech v2, fmic. a broken down 13.8 @ 97
                          200dx
                          sp135+
                          port-a-torch
                          miller big window
                          other stuff
                            Same here, my 80CF argon is down to zero and was still going when I stopped, also one of my 80CF C25's is down to 200CF. I phoned the dealer I get gas from to find out the cost to trade up to a 125CF and he will trade up to 150 but reserves the 125's for lease. Plus I would only save about 10% per fillup going to 150's over 80's. I think I will just plan on going to get refill's more often, as I am retired it's not that big of deal.
                            Regards, George
                              wow, i save a bunch going from a 80 to a 150. $29 for a 80, $37 for a 150.argon.
                              200dx
                              sp135+
                              port-a-torch
                              miller big window
                              other stuff
