running gear 235 AC Stickmate
  • running gear 235 AC Stickmate
    I bought the 235 AC stickmate which didnt come w/ running gear like the AC/DC model did. I am trying to find the running seperate to purchase. Any suggestions?
    Thanks Sparksinmysocks
    Looks to me a couple of mower wheels and some conduit. You bought this thing to fabricate? Time to start. Roy in this post built his, way better than the factory. http://www.hobartwelders.com/mboard/...&threadid=3660
      I thought you could buy it for $20.
      axehind
        Running gear
        Break out the rods and have it. Thats what its for and you can build a better one than you can buy most of the time. Also you can custom make it like you need it to be. The running gear is a good project to start on. Show us some pictures of whatever you decide to do. I'm fixing to make some wheels for an old Lincoln Idealarc 250. David
          Couple a wheels off an old wagon, some 3/8th's round bar, grind the attaching parts off of some bed rails, screw'em on and, wallah. Works for me. Also took some 3/8th's sq and bent and welded to the bed rail peices to pull it around with.
          This says its for Miller but the Hobart is the same machine.
          Click Here
          John
            No problem The part number is 043927. You can order it from the store you got the welder.
            Thanks for purchasing a Hobart.
            Dave Evans
              SPARKSINMYSOCKS...............WELCOME ABOARD....if you purchased 500418 or 500419 then you should of gotten the running gear standard in the hobart line-up.........Shoot me your serial number and I will see which model it was..........
              If you were suspost to get the running gear and I can tell from the serial number I will have one sent to you no charge.........The serial number is the key..........
              Enjoy the site.................Rock..
