I am running dual shield wire using 75/25 using a MM 210, I am producing some pretty nice looking welds. I have read where one should reverse polarity when running flux core wire ??? does this hold when running dual shield wire?
Dual Shield mig wire
Excel Arc 71
I am gearing up to repair several bushhogs , that is if it will ever turn cold here in LA, and the weeds and grass stop growing. I went with this type wire because a friend suggested I use this. He said he gets very good results welding "dirty" metal. I had checked with local distributors for this wire but none carried it. I contacted Hobart's district manager in my area and he provided me with a 33# spool. I have not welded a whole bunch with it but what I have I am very pleased.
How is the MM 251 treating you, I came within a thin dime of getting the MM251 but instead chose the 210. There is always a next time.
So far I am really impressed with the MM251. It has limits, but I knew those going in. They are high enough that the limits really shouldn't affect me very often, at least in real-world situations. I have already met them in testing, but I was doing this on purpose to find out exactly what they were.
So far, I can get excellent quality welds on 3/8", very good on 1/2", and acceptable on 3/4". These are using C25 gas and .035" solid wire. Now understand, my testing methods are not as precise as in a lab, but should be sufficient for a backyard hobby weldor anyway. I basically beat the living daylights out of my welds with a hand sledge and examine the failures, if they occur. I have a few pieces of 1/2" and 3/4" CRS barstock I butt welded that I have yet to break.
I have also tried spray-arc welding to see if it will be advantageous for me or not. The first bottle of gas I tried worked great for thin stock, and in short-arc mode, but not so well for spray-arc on thicker metals. This was an Airgas Steelmix-Extra. I now am trying a bottle of 98A-2O2, and it sprays at a much lower setting. I have no problem spraying even with the thicker steels, but I need to evaluate if it is worth it or not. The bead apearance is comparable to my short-arc C25 welds, no better.
Dan has suggested that I consider trying a dual-shield wire for my applications where I need better penetration. I am looking for some wire to try, but I don't want to buy a 33# spool of .045" wire, which requires changing my drive rolls and gun liner, just to try a new type of wire.
I'll keep everyone informed as I progress down this road.....Proud Owner of the MM251 and Spectrum 375 Cutmate
Aaron
You should be able to find the .035 in 10 lbs rolls. I would try E mailing Cyberweld or BRwelders and see if they can help.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
Dan,
I have looked at Cyberweld, but not yet at Brwelder. I had hoped to find some locally. My Airgas dealer is actually turning out to be a big help. We are learning together.
That's why I asked what the specs were on Chuck's wire.Proud Owner of the MM251 and Spectrum 375 Cutmate
Aaron
Chuck is running an .035 Hobart Excel Arc 71. My computer skills are weak so here is the best i can do to help you out with finding info on the wire. WWW.hobartbrothers.comMigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
Excel Arc 71
The excell arc 71, distributors here in Baton Rouge do not have a big demand for the .035 dual shield, their demand is for .045 dual shield. Hobart district manager also stated that his customers use the .045 dual shield, he rarely get a call for the .035, he had a 33lb spool shipped in from Huston asap.
Originally posted by Aaron
Any idea what I should expect to pay for this wire?
Well, I e-mailed cyberweld and they responded (very quckly) by telling me the smallest spool Hobart makes for Excel Arc 71 is 33#. I can get the Esab version locally in a 10# spool, I guess I'll try that - I probably wouldn't notice the difference anyway. Anyone anyone use the Esab?
Jason
________
vapir no2Last edited by jason; 01-26-2011, 06:18 AM.
