anybody use grinder for notching small tube
  • anybody use grinder for notching small tube
    i find that a angle die grinder is great for notching small diameter tube!.....anybody use this ideal?
    anyhows!....astro,chicage,ir,?
    Miller Stick Welder-Lincoln Stick welder-Torch set-30-06 Lever action Winchester,Marlin 22 Semi-Auto LR,Marlin 22 Magnum Bolt Action w/synthetic stock and stainless steel barrel-.45 Colt Revolver-Polaris Sportsman 500 4x4
    I used too... until I got a tubing notcher
      Nope, grinders are just for dress-up.
      either this or plasma...
      Fit-up with grinders is haphazard at best.
        Nice notcher Bluesman2a - you mount that on a drill press? I've been thinking about getting one, but didn't know if mounting it on the press would work.
          They are made to be mounted on a drill press. The one I got at HF though I just hook a cordless drill to it and put it on the floor and push down. It works well!
          T/A 185, HH 175
            Funny you should ask that. I've been running it mounted to my bender with a hand drill. This week I finally took the time to mount it on my press (it has a large slotted table, and the notcher needs to sit on the VERY EDGE to be able to take advantage of all 50* of angle cut available). I can't believe I was dumb enough to wait this long to do this!!! Makes a HUGE difference. Just being able to apply even, constant pressure has speeded up my notching by like 50%, and being able to clamp stuff to a STABLE, level base is a big bonus.
            Now you'll still need to take it off for the odd big-stuff, but I like my press mount a WHOLE lot better!!!
              fancy pipe notchers for press
              i just figured better to do it the good ol natural way with a blowpipe.too much time to get that all hooked up on my press when i don't need one unless i am working for nascar or some other racing company making roll cages 4 a living or making a 10 mile fence or doing factory production work.that's too good for my old-fashioned butt
              anywasy how much for one
                I don't do any of those things, but I DO make cages that will, if ultimately tested, protect me and those important to me. For that, I have no issue with spending a little more on a quality tool, a standard cage can have in upwards of 10-20 joints that require precise fit-up. Each of those points is an opportunity for failure, and I like to keep my odds as high as possible.
                If you're not building LOTS of cages, Harbor Freight sells a cheaper notcher for about $50, but it'll only be good for a single cage before you have to pitch it.
                Let me also say that if you can notch a tube with a 10* angle, on it, factor in a 20* rotation and do an 8* angle on the same bias all by hand with an angle grinder, AND get the kind of fit I can do in about 15 minutes, I'll come shake your hand.
                  Here's an example of the work I had to do just tonight, on a PORTION of a single cage, also shows my setup in the press:
                  For more pics of the whole project see here:
                    bluesman2a
                    Nice work on the jeep.
                    I've been thinking or purchasing a notcher, saw the HF one and questioned it's quality. Don't plan on doing any roll cages but I am thinking of making a headache rack for my pick-up. Who makes the one you are using?
                    thanks and have a great day.
                    Brian Sokolowski
                    Hobby Weldor
                      RE: anybody use grinder for notching
                      I use a Joint Jigger mounted in my bench vise and drive it with my 1/2 Milwaukee drill. That's the manufacturer's recomendation and I find it works fine that way. You need a drill press that will drop the table about 14" from the chuck to use the drill press option.
                      I chose the Joint Jigger because I can get a full complement of parts should I need 'em.
                      Bob G.
                        Re: anybody use grinder for notching small tube
                        I never had a tubing notcher.....always use a O/A torch or grinder. with a grinder it is quick and takes awhile to do it good, but with practice, you can master the technique. Most of my stuff I do in the field, no vise a lot of times, so it comes in handy.
                        I have to admit, tho a notched tube makes a nice fitup to weld.
                          Re: Re: anybody use grinder for notching small tube
                          Ah, here is where we separate the men from the boys... I have no doubt in my mind that somebody who does this day-in and day-out could get some good fit-up in a reasonable amount of time without a notcher. The problem is most hobbiests (myself included) just don't get the kind of exposure you're talking about to properly fit joints for critical/structural applications.
                          Plus I stink at working with crown-molding, anything that helps me deal with compound angles easier in tube makes me a happy camper!!!
