SKINNER...............IT IS A VOLTAGE SENSING FEEDER THAT WILL WORK ON ANY ENGINE DRIVE..................IS YOUR CURIOSITY PEAKED YET...............?...........JUST AS AN AFTER THOUGHT HERE IT WILL WORK ON ANY ELECTRIC STICK MACHINE........... I DO NOT HAVE A BOOK IN FRONT OF ME SO I CAN'T ANSWER IF IT WILL FIT ON A CV MACHINE......................FROM MEMORY I THINK SO......... (BUT THAT IS FROM MEMORY AND IT IS SHOT)........ I'LL HAVE THE FEEDER GUYS ANSWER THAT ONE...................... ...........ROCK [email protected]
the 3045fc will go on a cc or cv machine (switch inside door right above drive rolls). Needs 115V (2amp draw) for control input. From what I've read on it should go on most makes of machine.
THANKS BRIAN............. I HAD JUST CALLED RON WOODWARD TO HAVE HIM LOOK IN HIS MANUAL AND ANSWER THIS ONE......... ON THE CC/CV TAP............GLAD YOU COULD HELP..............ROCK[email protected]
THE UNIT IS RATED FOR CONSTANT CURRENT AND CONSTANT VOLTAGE........( 30 TO 350 IPM CC, 30 TO 600 IPM CV )........175 AMPS AT 60% DUTY CYCLE...... 225 AMPS AT 30% DUTY CYCLE...
