HH 175 and .035
  • HH 175 and .035
    Just wondering what peoples experiences were running .035 wire on a HH175. I've only run .030 in the past but was thinking about trying .035. Most of my welding metal thicknesses have been between 1/8" and 1/4".
    Thanks,
    axehind
    I run .035" almost exclusively, with great results. I really prefer the Hobart "Weld-it" brand wire, and a 10# spool is $20 at TSC.
    That said, the .030" is fine for what you're doing. Why do you want to change? As I said, I use .035". I'm just curious what your expectations are.
      Like Arron said it will run 035, but I preffer 030 in smaller machines as it gives ood performance on sheet metal as well as excellent on stuff t 1/8th and still works up to 1/4. I think it is prefferable to trying to choke 035 thru a small machine. Just like any machine of any type its going to last longer running it 2/3 over being wide open.
        I usually bevel the edges and I thought the .035 would "fill up" the bevel better and faster. As it's pretty obvious, I'm new to this and was going to give it a try.
        axehind
          Thats a good point.
          axehind
            Maybe this dosn't apply, but here's what I have found out with my MM175. It seems to like .030 ok up to 3/16", but performance from 1/8" up seems to be better using .035. I have yet to try .024 I am mostly just trying to get used to variable voltage and this [frustrating] wire tracking. After this weekends performance [lots of splatter, welds ok] I just about went to the dealer to trade for a HH175 [even if I lost money] or get MM210 [cept I really don't have the extra 5-6 hundred to spend]. I spent about two more hours this morning, after some sleep, with .035 wire and 1/8" & 3/16" steel and things are looking better, splatter is getting under control and penitration looks good. Wire is weldit. My wife thinks it's funny, I spent a lot of dollars, got a bigger, better [?]welder and I'm back where I started a year ago...I think I need to change my name from "Sundown" to "Humbled".
            Regards, George
              Here's why I use .035" wire:
              Back when I had my HH135 I was told that it was "really only good for .023" wire, and maybe .030" on the outside. So I bought a spool of each of these sized to try. As I tend to stay in the 1/4" range myself, I found the .023" just didn't work, and the .030" was better, but not what I expected. So I bought a spool of .035" wire, which was still an improvement. I showed my welds to a weldor, who told me they were too cold, that I needed MORE POWER! (my favorite)
              I upgraded to a HH175, and tried the .023" wire, which was worthless on the 1/4" stock. I tried the .030" wire, and it was much better. So I decided to try the .035", and I got excellent results. As Sberry said, I was running the unit wide open, but I got the results I wanted.
              I still have several spools of the .023" wire and .030" wire, but I imagine they're corroding as we speak, as they are close to three years old. The .023" is probably 90%+ full, and the .030" is probably at least half full.
                I was planning on keeping .030 in the MM175 but after this mornings performance I will be keeping .035 in it and have a 2# spool of .023 for sheet metal in a air tight container. That is, after I burn up the 6#'s of .030 I bought.
                Regards, George
                  I havent had to really go over 1/4" yet. And if I did, I would probably use my O/A setup up to 1/2" depending on the joint. I know most people will be asking "why use O/A when you can do multiple passes with the mig?". To answer I will just have to say it's my preference for now. I have practiced with O/A from 3/16" up to 3/8".
                  axehind
                    Dan,
                    Once again, you are the man. I had that chart sitting in the side pouch of the cover I made and never thought to look at it the whole weekend. If I read it right 3/16" is just out of the range of .030, and all my trying this weekend confirmed that, at least for me. Good thing I loaded .035 in this morning before I went to the dealer and made a fool of myself . As they say, you never stop learning something new [even if it was something I should have known]. BTY, I have started a spreadsheet for the MM175 settings. I'll email you a copy tonight, let me know what you think...
                    Regards, George
                      Would you mind sending it to me as well, I have been playing around with the settings and being less experienced then many of the others here some direction either way would help. I was doing some 1/4 inch this weekend and was getting a fair amount of splatter and was having trouble getting it dialed in. I had it set pretty well with the .030 and .023 on thinner metal but having a little trouble with the thicker stuff. [email protected]
                        axehind..........I have used quite a bit of .035" wire in my HH175 but I use mostly flux-core. Most of my projects seem to require thick metal. Almost everything I do requires 1/4" or more. Here is a picture of a 3 point trailer hitch I welded up. The materials used were 1/4", 3/8", 5/8" and 2"square solid. It seems to be holding up quite well so far. I really like flux-core wire.
                        bitternut
                          Here is a picture of the hitch being used to haul out a couple of 20 footers.
                          bitternut
                            On my Hobart Betamig 200 I run about 100 amps with .035 wire. I was watching a welder friend of mine's big Lincoln while he was welding. The guage was right at 100 amps.
                              rjgogo,
                              Done, make sure you read the disclaimer
                              Bitternut,
                              That is very impresssive, thanks for posting those pictures.
                              Regards, George
