I normally turn off the gas flow of my tank after each use of my HH175, but from time to time I find myself forgetting to turn it off for the night.
If I continue to keep forgetting, will I ruin the built in valves of the HH175 ? Is there anything else I will prematurely ruin?
ALso, when I turn my gas flow open, should I turn the gas flow completely open (6-7 turns of the valve) or should I turn it just enough to get the pressure gauge to read ? Assuming one way is worse than the other...WHat bad things will happen if I turn the valve partially open or fully open ?
