Strapping diagram for Hobart CT-200
  • HRod
    Hobart CT-200 Spec. Number
    Thanks for the reply, Rock.
    Ah, Monday morning haste.
    I apologize for my hasty post. I have previously requested a manual for one Hobart CT-200, spec. #5518, serial #8RT-12402 through the service department on this Hobart web site. I was informed via email the unit was too old, and the manual would have to be purchased through a third party. It appeared that $50.00 was the required fee. Now $15.00 is reasonable in my opinion, but $50.00 is a little much. I opted to see if anyone here could help out.
    If a schematic is handily available, please send, my fax #: 931-359-8664, or email: [email protected].
    Again, thanks for your time.
    Rod
  • Hobart Expert Rock
    HROD................Welcome Aboard...........The only way to get one now is order the Manual for the machine...........cost is $15.00 usa funds.........call 920-735-4197 this will put you in contact with barb or Sara in the manuals department. You can only order by the specification number of your machine. If I had a schematic for the voltage change over I would fax it to you. However there are 3 different versions of your machine. Safer to purchase the manual they can not fax you just the voltage change over.........
    Be safe....................Rock.......
    [email protected]
  • HRod
    started a topic Strapping diagram for Hobart CT-200
    Looking for strapping diagram for a fairly old Hobart CT-200 tig welder. It was set for 460 Volt, single phase, and I need to set it for 240V, single phase.
    The wiring diagram on the inside cover of course is missing.
    Thanks for your time.
    Rod
