Strapping diagram for Hobart CT-200
  • Strapping diagram for Hobart CT-200
    Looking for strapping diagram for a fairly old Hobart CT-200 tig welder. It was set for 460 Volt, single phase, and I need to set it for 240V, single phase.
    The wiring diagram on the inside cover of course is missing.
    Thanks for your time.
    Rod
    HROD................Welcome Aboard...........The only way to get one now is order the Manual for the machine...........cost is $15.00 usa funds.........call 920-735-4197 this will put you in contact with barb or Sara in the manuals department. You can only order by the specification number of your machine. If I had a schematic for the voltage change over I would fax it to you. However there are 3 different versions of your machine. Safer to purchase the manual they can not fax you just the voltage change over.........
    Be safe....................Rock.......
      Hobart CT-200 Spec. Number
      Thanks for the reply, Rock.
      Ah, Monday morning haste.
      I apologize for my hasty post. I have previously requested a manual for one Hobart CT-200, spec. #5518, serial #8RT-12402 through the service department on this Hobart web site. I was informed via email the unit was too old, and the manual would have to be purchased through a third party. It appeared that $50.00 was the required fee. Now $15.00 is reasonable in my opinion, but $50.00 is a little much. I opted to see if anyone here could help out.
      If a schematic is handily available, please send, my fax #: 931-359-8664, or email: [email protected].
      Again, thanks for your time.
      Rod
