Hi Again,
I have a chance to buy a barely used Miller Spectrum 375 plasma cutter for $750.00. I would really like to have the Spectrum 625 because of the higher duty cycle, but I since I will be on sick leave for another month and actually have time to use the plasma cutter, and don,t have the funds for the 625, I think I will get the 375. I have all the needed wiring to run the cutter but I am not sure about the compressed air. I have an older Sears 2hp air compressor that has a 12 gallon tank on it. I can not find any information (or part number for that matter) that states the capabilities of this compressor. I do use this compressor for my impact wrench and it gives me enough torque for lug nuts. On the other hand when using my air cutoff tool it will draw the air from the tank in a hurry, and the compressor is constantly running. Judging from these examples I have no idea if this compressor is capable of supplying enough air for the plasma cutter. The manual states the the plasma cutter needs the following: Plasma Gas Flow/Pressure 4.5cfm (129 L/min) at 60 PSI (414 kPa). Can someone tell by the examples I provided, or is there any way I can test the output on this compressor. I am hoping for good news because I can't afford a new compressor at this time.....thanks
