MM 175 and aluminum
    BUGEYEDVALIANT......... HERE IS THE SKINNY............. THE HANDLER WILL WELD ALUMINUM........ BUT YOU BETTER BE PRETTY EXPERIENCED OR PREPARED TO PRACTICE A LOT ON SCRAP PIECES OF ALUMINUM.......... THE HOME HOBBIEST TYPE WILL NOT HAVE A SPOOL GUN LAYING A ROUND........ HOWEVER THE COMMERCIAL TYPE BUSINESS PROABABLY DOES............ WERE JUST INTO TWO DIFFERENT MARKETS....... YOU CAN ALSO PUT A SPOOL GUN ON THE HANDLER WITH THE RIGHT CONTROL BOX............ IT IS A LOT EASIER TO WELD ALUMINUM ONLY PUSHING THE WIRE 6" AS YOU WOULD WITH A SPOOL GUN VS THE 10' IN A MIG GUN................. HOWEVER YOU CAN DO IT WITH A LOT OF PRACTICE...............HOPE THIS EXPLAINS THE SERERIO AND YOU NOW HAVE THE ANSWER....................ROCK............[email protected]
  • BugEyedValiant
    started a topic MM 175 and aluminum
    MM 175 and aluminum
    Why is the HH175 recommended to weld aluminum and the MM175 requires the spoolgun? I know that MIG results are not as good as with my Syncrowave, but is it practical to do with the MM175?
