Plasma Cutting
  • Plasma Cutting
    Looking for options on a metal cutter. I just do not want to rent (or buy) acetylene cylinder and oxygen cylinder. I have a 14 inch chop saw, but looking for something to cut patterns out of 1/16 up to 1/4 plate steel. I do like the Plasma cutting method, but they are over $1000.00 bucks (with the build in compressor). Is there any other options to look at?
    Thanks in advance.
    Dave
    laser cutter
    high pressure water jet
    flex linular shape charge
    die cut
    grit saw
    hacksaw
    bandsaw
      Originally posted by Roger
      laser cutter
      die cut
      grit saw
      hacksaw
      bandsaw
      Don't forget that Opetrol gasoline torch thing!
      Bill C
        Well, might as well throw in a wire edm.
        Jason
        ________
        buy cheap vaporizer
          When he ruled out acetylene and oxygen I ruled out all oxy/fuel cutting. Was going to include hammer & chisel which would work but 1/8" to 1/4" is a little thick cold.
            You forgot Carbon arc cutting/gouging
            Scott Schering
            http://www.pontiacs.org
              Thanks for all the advise.
              What would be the cheapest way to setup a plasma
              I am sure alot of folks here have different configurations.
              Dave
                Ultrathermic/exothermic cutting
                SMA Cutting (was a farmer once)
                  What about a phaser?
                  Not sure what setting he used but Captain Kirk successfully cut through many a bulkhead with his phaser.
