Ok fellas...question for the "old timers"...
. Since Im sure some of you guys have clipped off more wire from your MIG guns to control the stick-out...than I''ll ever actually USE....I have a few questions!
My future welding will all be "mild steel"..thickness will range ( normally) from thin sheets to "about" 1/4 inch. ( Maybe slightly thicker if and when I get an additional larger; welder. ) So..your recommendations on the "best" ( relative term) wire; brand, model...etc to use for the following would be GREATLY appreciated. Wire READILY available is also a big asset ( I dont need to wait on "them" to dig the iron ore out of the ground to make a batch..if you get my drift...
..) ALSO...I really dont have much "need" ( at this point) for anything that can ONLY be bought on those HUGE spools.
1) .023-.024 solid wire for use with 75/25 gas
2) .030 FluxCore (presently using E71T-11 )
3) .030 solid wire for use with 75/25 gas for if / when I get a larger MIG outfit
Input is greatly appreciated.
