HBS Model 1 Bender Test
  • HBS Model 1 Bender Test
    As some of you know I purchased one of these benders and said that I would post results of testing. Here is everything I know about it so far. It has dies to do pipe and tubing 3/8, 1/2, 9/16, 5/8, 3/4, and 7/8" round & 3/4, 1" square. I did not try any pipe as I purchased it for tubing. It is very heavy duty and looks like someone's idea of a cross between a conduit bender and a tubing bender. I could not tell where it was made, as there are no markings at all. The quality is better than HF china stuff, about what you would expect from Taiwan I think.
    Before I ordered it I sent two emails to the company and told them that I wanted it to be able bend 1" square 16ga tubing, they assured me twice that would be no problem. I tested it on 1/2" OD, .050 copper, 1/2" OD, 050 Alu, 1/2 EMT [using the 3/4" die], 3/4 EMT [using the 7/8" die], 1/2" square 16ga tubing, 1" X 1/2" rectangular 16ga tubing, 7/8" 16ga round tubing and 3/4" 16ga square tubing with no big problems. The 3/4" was a bit tough to get out of the die, it probably will loosen up with use. As for 1" square 16 ga, not in my lifetime. RPM1 came over along with the guy across the street and even using a 3 1/2-foot cheater bar [floor jack handle] we could not do it. We could get it to start but the force needed bent the die frame and the smaller die would start cutting into the side of the tube and halt all progress. The frame returned to normal as soon as pressure was released. Frankly it would take a very, very tough guy to break this thing. I tried to get some 1" square 18 ga tubing to test but all the suppliers laughed at me, some said it wasn't made. I don't believe that, but that’s what they said.
    When I first started to talk with the company I received answers to my questions the next day. When I started to complain about the 1" 16ga square tubing problem, they first wanted to know what the problem was because they have "customers bending heavier stuff with no problems". The second time I complained they said "send it back we will refund your money", I called them to ask about their policy on refunding shipping costs and was told someone would get back to me soon. That was 8 days ago and no answer yet. I sent an email a few days ago that has not been responded to yet. My guess is because the shipping would be a total of $80.00 [both ways] they don't want to refund it. The product costs $119.00 and does most of what they say it will, so I have decided to keep it. It has a one-year warranty; I really don't know what that means because there was no paperwork included with it and no information on their old website. This product was not listed on their new website that I could find; only the $20,000 plus benders they sell.
    If you want one of these I think that it will bend 1" Sq Alu tubing with no problem, and most probably 18 ga 1" square steel also. Other than cleaning up the casting on the large dies some and getting rid of the sharp outside edges of the small dies the thing will do all but the 1" square [at least that is my experience] with no problem. Be sure to use lots of grease on everything.
    I have included pictures of the bender assembled and of the tubes I bent. If anyone has any questions please ask. I will try my best to answer them. One other thing, even if this looks a lot like a conduit bender, it is not. It is much heavier than that, and the 1/2 EMT is a little small for the 3/4 die and the 7/8 die is a little small for the 3/4 EMT. I know I did it anyway, you just need to take it slow and keep checking the conduit as you proceed.
    Regards, George
    HBS Model 1 Bender
    Here is a picture of the softer bends:
    Regards, George
      HBS Model 1 Bender
      And last the harder metals:
      Regards, George
        That thing looks like they crossbred a set of Imperial Eastman bender with a roller.
        ONE BIG CAUTION ~ with a bender of this nature make real sure the vise and bench are well secured cause eventually someone will apply enough force to flip the bench.
        If the dies are decent quality, you got your money's worth for the price. You sure couldn't make them for that money.
          Franz
          The casting on the dies is not to bad, just a small bit of cleaning up needed. The roller dies are good the way they are. I think I might rig up a frame and hyd jack to use the 1" square die in so that I can do 1" 16ga sq tubing easily.
          Regards, George
            Before going to the trouble of creating the hydraulic, would you be able to attach a come-a-long to a pipe handle and see if the thing will actually hold up to the force you need to bend the square tube?
            The neck of the roller handle looks a bit weak for hydraulic forces.
              Franz,
              Thanks for the concern, I was not planing on using the handle and small die. I was think more in terms of setting up something on the order of the HF pipe benders, only on a smaller scale, and only use the large die (it looks very strong. If I do it I will be sure to use all safty rules). Again thanks...
              Regards, George
                BENDER
                I JUST PURCHASED A PRO-TOOLS PRO-105 BENDER PRICE WAS ABOUT TWICE AS MUCH BUT I HAVE BENT 1" 16ga WITH ONE HAND AND THEY SAID I COULD BEND 1 1/2" SCH40 EASILY. I THOUGHT THAT WAS A BIT MUCH BUT GUESS WHAT WE DID TODAY, YEP 1 1/2" SCH40. THEY DIDN'T LIE JUST LIKE AS SIMPLE AS THAT. THEIR WEBSITE IS WWW.PROTOOLS.COM SORRY I COULD NOT WRITE SOONER BUT I WAS CHECKING THEIR CLAIMS BEFORE I PASSED THIS ON,I LIKE GOOD TOOLS AND HONEST COMPANIES EVEN MORE!!!!! PISTOL8
                  Pistol8,
                  I think you need the hyphen in the web address given...
                  After over 30 years in business, Pro-Tools remains the #1 choice of metal fabricators for high-quality tools at an affordable price. Shop now! MADE IN THE USA
                  Thanks for the info.
                  Jeff
                  MM 210
                    DASH THINGY
                    JEFF YOU ARE CORRECT THANKS I CAN'T TYPE EXCEPT WITH ONE FINGER AND I HAVE NOT FOUND OUT WHICH ONE IT IS YET. PISTOL8
