A good friend is looking to upgrade to a 200-250 amp mig unit. Looking for suggestions. Thanks
Suggestions on a Mig unit 200-250 amp
Originally posted by aweaver
Seems like a good friend would recommend a blue one, probably a MM210 or MM251. The MM251 would be my choice.
Aaron
Having ran both the MM 210 and the MM 251 I feel you can t go wrong with either machine. It mainly comes down to which machine meets a persons needs and budget.
The MM 251 has a nice crisp short circuit transfer arc and the MM 210 has a nice smooth soft short circuit arc. Both produce almost spatter free welds. The drive roll assembly and guns are the same, so there is no advantage or disasvantage between these two features. For adjusting the machine I really like the meters on the MM 251. However, in my experience the parameter chart on the door of the MM 210 is right on for flat and horizontal fillets.
If I could only have one of these machines it would be the MM 251. However, since I already have the MM 210 and I am not going to part with it, I m patiently waitingto add the MM 251 too
. what can I say I m greedy
when it comes to welders
