engine manifold
  • engine manifold
    i was told that somebody on this would be able to help me!
    I am looking for a exhaust manifold for an older hobart welder with a 4 cylinder gasoline engine.
    Model #gpb 258 Serial#12cw26026 Spec#2489c These are all the numbers ive found on the machine if it helps. and if it makes a difference the distributor comes out the side. If anyone could let me know where i could find a new or used one it would be great.
    Thanks,
    Ty Gray
    SPEEETY....... WELCOME ABOARD....... FROM THE SERIAL NUMBER I CAN TELL YOU THAT YOUR MACHINE WAS SOLD ON 08-12-1962. IT WAS SOLD TO AIR EQUIPMENT AND SUPPLY IN CARLSBAD NEW MEXICO..................IT HAS A WILLIES ENGINE IN IT MODEL 914361 WE AT MILLER/HOBART HAVE NO PARTS FOR THIS MACHINE LEFT.................. HOWEVER THERE ARE NUMBEROUS CLUBS JEEP AND WILLIES CLUBS THAT SHOULD BE ABLE TO HELP. AT ONE TIME THEYRE WAS A PLACE IN ATLANTA CALLED APPLIED EQUIPMENT, MY SON AND I RESTORED A OLD JEEP QUITE SOME TIME AGO AND FOUND EVERYTHING WE NEEDED AT THIS LOCATION MOTOR WISE..................BEST I CAN DO.......ROCK..
    SSCO[email protected]
      I'm going way out on a limb here, but I think that if that motor is a willys part it is more than likely a continental motor, those were used in a lot of industrial equipment(Ford 8n tractors and others)
      Maybe check a farm equipment salvage yard. Good luck.
      Mike
