Need a Converter Box for a SA200 Lincoln welder
  • Need a Converter Box for a SA200 Lincoln welder
    I have a Lincoln SA200 F163 Lincoln welder. It will produce 120 DC from the receptacle, but I want to convert this to 120 AC. Is there a convertor box for this model that will take care of this? Please email mseymour@soonet.ca - many thanks,
    Mike
    I would just get a small generator sized to the amps you require.
      You can easily convert AC to DC. But it's not worth the trouble to go the other way.
      Depending on the capacity you need an inverter may do it for you.
      Syncrowave 180 SD
      MM185 with 3035 Spool gun
      Stars-n-Stripes Big Window Elite
      ESAB 875 Plasma Torch
      Purox O/A
      Century 250A/C-D/C BuzzBox
      1.5 kVA Spot Welder
      Phoenix Electrode Conditioning Oven
      Professional Auto Mechanic since 1974
      My own shop since 1981
      Cya Frank
        you can buy them inverters that is from HF but most are for 12v dc to 120v ac i installed a belt drive genarator to the engine belts on the 400 amp lincoln that i have and it works great also no need to speen up engine works at idle speed also used a electric clutch so as not to burn it up when running high speed vwery simple to do
        MILLER 300 DEISEL
        MILLER 2050 PLASMA
        MILLER DYNASTY 200DX
        RYOBI CHOPSAW
        ANGLE AND BEVERLY SHEAR
        MILLER 250HF
        MILLER REGENCY 250 SPOOLMATIC GUN
        S22P12
        LN25
        SAE400 DEISEL
        2 WELDING TRUCKS AND OTHER STUFF
