just inherited several H.D. 10" c- clamps some are wilton, however some have missing swivle pads, some pads bad from cutting off welds. No one around here knows if they can be repaired. anybody got any suggestions ?
C- Clamp repair
c-Clamp repair
widetrackman,
Check out the following thread. Repair kits are available or make your own with washers or machine bolt heads.
Dave"Some days you're the dog, some days you're the fire hydrant"
Re: c-Clamp repair
Originally posted by Dave Haak
widetrackman,
Dave
speaking of c-clamps ... almost every c-clamp I have is warped. my suspiscion if that I'll get one pretty tight holding something together and then I'll weld close to it. Then the clamp will soak up all the heat from the weldment and with the force I've placed on the clamp it will twist the C part of it a bit. any ideas to unwarp them ?
- jack
Morphes, are your weldments next to a fordge? Ha HA just kidding. I' ve never had any fordged HD 5" & up warp ( yet ) althougt have warped some 2"- 4" el chepos from trying to twist them to tight. If you have twisted fordged clamps, I too would be instrested in how to straighten them. happy welding.
