Rock, or anyone else with an idea.
Hoping to remedy this without losing several days for Miller to get it fixed.
I have about five rolls of .030 hard wire through a pretty new MM251. Welder started popping and acted as if it wasn't feeding properly(like rusty wire). Took the opportunity to install new liner(correct length/no burrs), and tip. Welder still acts up intermittently.
Changed out drive rolls and checked allignment. Still probs.
Bead looks and acts as if you cut voltage by 1/3 and kept welding. It does not seem to be heat/time related. No kinks in the gun. Wiper installed on the wire. Can pull wire off the roll, through gun/ liner by hand with minimal effort. Am using same roll of wire and cylinder of 75/25 gas I was using previously. Tension is set right.
Any service bulletins, Tech. advisories, known quirks, etc.
PS- I guess I forgot my manners... This is a very informative forum with an intuitive bunch of folks. I may not say much but do quite a bit of looking.
