The only one I've read about is by Weldcraft. Is this the most durable one, or is there another I should take a look at? 250 amp, water cooled is what I'll be needing.
metal tech,whatever brand you buy,don't flex the head very much or you will have problems.The Weldcraft SF-225-25-HD has the interchangeable torch heads,and the flexbody.It comes with 9 style head,and is 70 degree.It also comes with a larger 1726-70 degree head also.The cool thing about this torch is for about $20.00 or so you can get a 180 degree head,and also 90 degree heads.That will keep you from bending the torch too much.
