what machines is it compatable with? what machine is it a direct hook up with? wondering if it would fit a MM210
185 spool gun
Hi Butthead. The Spoolmate 185 will work on all competitors machines under 250 amps. You will need a SGA 100 box part no 043856. When using it on a 250 amp machine you will need to take some caution. The gun is rated at 150 amps at 60% duty cycle. Most 250 amp machines are rated at 200 amps 60% duty cycle. There is more machine than gun. The gun will hook directly to a Millermatic 210. It will also hook directly to a Millermatic 185 with the addition of a part no 207642 switch and diverter valve after serial no kh376829. It will also work with Millermatic 185 before that serial no with a kit part no 186871 and a 207642.
HI BUTTHEAD........... DOUG..........OR YOUNG DOUG AS WE CALL HIM WORKS AT LIGHT INDUSTRIAL AND IS ONE OF OUR SECRET AGENTS............... YOU WILL NOTICE HE IS MATICULOUS AND HAS ALL THE ANSWERS DOESN'T HE........................THANKS YOUNG DOUG................................ROCK.......... ........
[email protected]
One more note I'd like to add ...
If you are going to use the spoolmate 185 on a 250 amp machine you can change the barrel assembly of the spoolgun to the barrell assembly from the spoolmate 3545, part number 196827. That will give the spoolgun a rated out put capacity of [email protected]% duty cycle.
Mike
