Just purchased Hobart 210
  • Just purchased Hobart 210
    I just purchased a Hobart Ironman 210 the other day. I have never welded a single piece in my life. I was wondering if this was a good choice for a begining welder?? Any pros or cons to this choice??? Thanks
    Ive never welded in my life!!
    You made a good choice. Most people buy too small and wind up having to trade up to 210 or 150 amp.
      This machine should do a good job for you. I like the MM 210 a little better, but this is still a good choice. In the future, once you have logged a fair amount of practice time, if you use this machine on any 1/4" or thicker mild steel that is going to see loading a self shielded fluxcore is the best choice with this machine. If you need to know the why on this just ask.
        Re: Just purchased Hobart 210
        you got yourself a good rig, but if you prep your metal,(bevel the edges) you do not need self shielded wire to insure a sound weld, even with a 175.
        Ninety percent of a good weld is planning and prepping, not just throwing a lot of amps and hoping.
        ROCK
          Thanks for the input guys. Im sure I can use all the help I can get.
