i am going to buy a plasma cutter.sure need some input.i have portable band saw, a husqvarna gas chop saw.torches. i will run it mostly with a hobart champion 10,000. i have had really bad luck with a mm 120 ,so would like to try something else. 1/2 in is as large as i will cut. ineed to cut straight cuts and i can't do that any more.
plasma cutter
Re: plasma cutter
HI DULKNIFE........... I DON'T THINK I'VE EVER RUN ONE (SPECTRUM 625) OFF OF A CHAMP 10000............. SO WILL BE INTERESTED IN SEEING HOW ONE RUNS........ IF YOU HAVE A LOCAL DISTRIBUTOR IN YOUR AREA LET'S GET HIM TO HOOK IT UP TO YOUR CHAMPION 10000 AND TAKE HER FOR A TWIRL............. I THINK THE ONLY THING HE (THE DISTRIBUTOR) MIGHT HALFT TO CHANGE IS THE PLUG........ I THINK ALL WOULD BE INTERESTED IN YOUR FEED BACK........SOUNDS LIKE AN INTERESTING TOPIC FOR DISCUSSION AFTER YOUR FEED BACK........... TELL US WHAT YOU LIKE AND DON'T LIKE ABOUT THE SET UP........... YOU KNOW WERE ALWAYS INTERESTED IN FEED BACK................ YOUR CALL....ROCK
[email protected]
