What type of wire for my Hobart 175
  • What type of wire for my Hobart 175
    Most of my welding now is fast repair jobs on rusty farm machinery. I presently run solid .30 wire with 25/75 gas. A friend told me that if I switched to flue core wire and run gas also I could get better weld on rusty metal. I try to clean metal up with grinder and wire wheel but you can't get to all the rust. The metal I run into ranges from 16 gauge to 3/8". The thicker stuff I turn on my buzz box and stick it. Solid or flue core?
    You probably will have better results on dirty material with flux, but even with solid wire I think you need .035. If you run flux core, I think you want a duo-shield type if you run gas with it. best bet is probably stick for quick & dirty.
      It can be a little eaier to change the characterisics of the weld with flux and it works better out doors and better with dirty conditions. You can use a torch to clean metal sometimes too. A lot would be if you minded the flux in between passes. We use solid here because its so much easier to clean and faster for poor fitup. Use a stick if its dirty.
        HAYMAKER......... I AGREE ........ I USUALLY TRY AND CLEAN UP THE DIRTY MATERIAL AS WELL AS POSSABLE...... NOTHING CONTAMINATES THE WELD MORE THAT MILL SCALE, ETC....... I'VE HAD SOME SUCESS USEING FLUX-CORED AND CO2.....IT TENDS TO DRIVE THE ARC DEEPER.......... HOWEVER WE CLEAN THE MATERIAL AS BEST AS POSSABLE FIRST................ BE SAFE NOW...........ROCK.................
