I just got a tank of pure CO2 and I wont make that mistake again. In the mean time does pure CO2 need different settings compared to CO2/Argon mix for the same job? How much nozzle pressure and wire speeds etc...
Mig settings for pure CO2 welding
Originally posted by TarponslayerI just got a tank of pure CO2 and I wont make that mistake again. In the mean time does pure CO2 need different settings compared to CO2/Argon mix for the same job? How much nozzle pressure and wire speeds etc...
Generally, it likes higher voltages and wire speeds than C-25 for like thicknesses. Flow rates are the same.
Hank...from the Gadget Garage
MM 210 w/3035, BWE
HH 210 w/DP 3035
TA185TSW
Originally posted by hankjWhat is it about the CO2 that you don't like? I've had great success with it welding mild steel.
HankHH 180
Craftsman 110V MIG
That means you have gone beyond the "short arc" mode of metal transfer and are in globular. Back off the voltage and WFS until you don't get spatter.
Not welding fast enough? Go to thicker wire.
Which welder do you have?Hobart Betamig II
Hobart Betamig 170
Lincoln Roundtop 250 (Stick/GTAW)
Clausing 5913 Lathe
Gorton 1-22 Mastermil
Johnson J Bandsaw
3HP 220V Chop Saw-Chain Drive
"You see, wire telegraph is like a very long cat. You pull his tail in New York and his head is meowing in Los Angeles. Do you understand this? Radio operates the same way: You send signals here, they receive them there. The only difference is there is no cat." A. Einstein
Tarponslayer,
Take the same steps with CO² shielding gas as you did with C-25 to find the sweet spot. Belive me, there is a sweet spot for CO². It's all I've ever used on the MM135, and I weld with virtually no spatter!
I'd second guess Benesso's recommendation to jump up in wire size. It depends on your machine. Some (like my MM210) like a diet of one wire. The macine's characteristics make the difference.
MM 210 w/3035, BWE
HH 210 w/DP 3035
TA185TSW
Tarp,
I prefer CO2 over a mix. I've never had a spatter problem with it. I don't do any of the art type stuff though, so maybe what I call "no spatter" would seem severe to others. My Miller, Linde, and Air Procucts machines run very good beads with CO2. The price diference is well worth it IMO.Clay
Anything that don't kill ya' only builds character...
I also get very little spatter with CO2 and .035 wire with my Hobart. I first time I tried C25, I had a lot until I dropped the voltage down. I haven't seen any data concerning voltage settings for different gases.What do I know I am just an electronics technician.
Originally posted by Mike WI also get very little spatter with CO2 and .035 wire with my Hobart. I first time I tried C25, I had a lot until I dropped the voltage down. I haven't seen any data concerning voltage settings for different gases.
Mike,
Typically, for the same (roughly) amperage value, CO² is going to require 1 to 2 volts more than a C-25 gas mix. BTW, you CO² guy are alot like the guys who swear stick is the only way to go.Last edited by Dan; 02-17-2006, 12:43 AM.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
LOL Dan. I figured you would show up sooner or later.What is the theory behind needing to drop the voltage for C25? I was trying some C25 and .024 wire the other day on some .064 wall tubing. It was working but seemed a little cold. I finally took the CO2 and .035 and used it, I felt better.
Originally posted by Mike WLOL Dan. I figured you would show up sooner or later.What is the theory behind needing to drop the voltage for C25? I was trying some C25 and .024 wire the other day on some .064 wall tubing. It was working but seemed a little cold. I finally took the CO2 and .035 and used it, I felt better.
Originally posted by Mike WThat is one of my favorite sites, good info there. Leaving out spray arc, CO2 delivers more heat to the weld compared to C25.I started out using CO², I actually ran strictly nothing but CO² for the first ten years. Then I tried a bottle of C-25, and haven t had a desire to go back to CO² since. I just prefer the nicer arc of C-25. With my power sources, producing sound fusion between the basemetal and weld metal is no problem with C-25 on the material thickness range that I weld on. You won't catch me trying to weld 1/4" with a little 120V unit. It just isn't going to happen. Not that CO2 is going to help a 120 v unit that much. The output voltage just isn t there to take advantage of what CO2 has to offer over C-25.
That MIG handbook on ESAB's site, came with my Migmaster 250 as a paper back book.If ESAB sells it to the public I'd recommend it along with the hand book that Miller offers, both are very good.
Last edited by Dan; 02-17-2006, 11:45 PM.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
10-4 Dan.I guess I am so used to CO2 that it is like an old pair of boots that fit well. From your experience what would be the maximum voltage that a power supply would need for spray arc?
