Handler 175
  • Handler 175
    Howdy from Colorado! I recently purchased a Handler 175 and have a Ranger 8. Question is: How do I hook up the Handler 175 to the Ranger 8 and what potential problems do you know about?
    thanks,
    kcoon
    kcoon
    The Handler 175 will plug into the 220 volt receptical on the Ranger 8. The Handler only pulls 20 amps on the input so I see no problems with the Ranger suppling enough input current to run the Handler.
    Dave Evans
      Gee a Hobart Expert who doesn't use ALL CAPS!!!!!
        Re: Handler 175
        thanks,
        kcoon
        Thank you Dave. You did not mention any problems and from what you wrote it should be fine. I will give it a try.
        kcoon
        kcoon
          KCOONEY.........WELCOME ABOARD............. WELL HOBART EXPERT MIKE DOESN'T USE ALL CAPS EITHER.......... JUST ME.......... BY THE WAY THE HANDLER DRAWS 20 AMPS BUT IF MEMORY SERVES ME CORRECTLY YOU HAVE A 25 AMP CIRCUIT BREAKER ON EACH LEG OF THE 230 VOLT OUTLET DON'T YOU........... SO YOUR RUNNING IT ON A 50 AMP CIRCUIT............... THINK SAFETY HERE NOW.....ROCK
            Rock:
            I will need to check that out. If there are 25 amps to each leg what ramification will that have with my plugging it in? The Handler 175 I have is 50 amp 220 volt. The ranger can put out 60 amps. What are the primary safty concerns?
            kcoon
            kcoon
              I have run my Lincoln sp175+ off my Ranger 250 quite a few times with no problems,not sure what kind of saftey issues your concerned about?
                KCOONEY...........I ALWAYS LIKE TO SEE A MACHINE RUN ON WHAT IT WAS INTENDED TO RUN ON 20 AMPS ON A 20 AMP CIRCUIT....... YES IT WILL RUN BUT IF THE UNIT (MIG) GET'S INTO TROUBLE THE POTENTIAL IS THERE TO EXCEED THE 20 AMP DRAW AND NOT KICK UNTIL IT HIT'S 60 AMPS.............. SORRY ONE OF THE DRAW BACKS TO THIS JOB IS ALWAYS THINKING SAFETY.......... DOES THAT MAKE SENSE TO YOU.......................?...........ROCK...... [email protected]
                  We better chill on knocking ROCK's typing. He might expel us from class one day.
                    COPE................HAHAHA.............I CAN'T SPELL WITH OUT A DICTIONARY........... ..... I CAN'T WAIT UNTIL THEY GET SPELL CHECK TURNED ON HERE.............. THEN I WILL LOOK LIKE I KNOW EVERYTHING.............HAHAHA.................SEE YA.....ROCK [email protected]
                      There is not any problems hooking this welder up to the Ranger 8. I know the Ranger has the 60 amp breaker on it, But the Handler has a 20 amp breaker on the back of it that protects the welder from over current, This will trip if there is a problem first.
                      Dave Evans
                        As long as you have atleast a 5,000 watt generator you will be able to run the Handler 175.
                        Dave Evans
                          Good morning! Last night I hooked the Handler 174 up to the Ranger 8 and it worked beautifully. Now I need to get some cables for the Ranger to use the stick and a power line to run the Handler 50ft. away from the ranger. Then I will be equiped without the knowledge. Thanks for all your help. kcoon.
                          kcoon
                            STEVEH..........CHECK THE COLEMAN/ HONDA WINDINGS... THE LAST COLEMAN I SEEN WAS 5000 WATTS WITH ALUMINUM AND HAD A HEATING PROBLEM RUNNING ONE OF THESE LITTLE UNITS OFF OF IT.................YOUR CALL................BE SAFE.........ROCK... [email protected]
