Anyone use or seen a demo on the new Miller 8RC suitcase feeder. I am tired of lugging around a Millermatic 135.
suitcase welders are great, however they are just a wirefeeder, not power source. they're generally for use outdoors. ive never used this model, but im sure its good. I run a hobart hefty from my lincoln sa200 when on site. what power source will you use? youll need 200 amps or better.
I'm running a new style Trailblazer with remote. I've used other voltage sensing suitcases in the past and couldn't justify them. This particular feeder uses open circuit voltage, is controlled at the feeder, and has no voltage sensing lead. I'm trying to find some testimonials on this particular feeder. Thanks.MM251 (shop)
Trailblazer 301G
8 RC feeder
RS 32 feeder
MM 130
TXBUSTER...............WELCOME ABOARD........... I HAD THE OPPORTUNITY TO WELD WITH ONE WHILE AT PORTABLE POWER.......... GRANTED WE WERE DOING TESTS WITH BOBCAT'S AND TRAILBLAZERS USING THE VOLTAGE SENSING FEEDERS AND THE REMOTE CONTROL UNITS........... BOTH SEEMED ADEQUATE TO ME.............. THE UNIT WILL FUNCTION ALL THE WAY UP TO 330 AMPS...............JUST MY 2 CENTS WORTH..............CAN YOU STOP BY YOUR LOCAL WELDING DISTRIBUTOR'S AND SET ONE UP AND TRY IT.................. THE ONE I USED HAD THE FLUX CORED GUN ON IT.....................YOUR CALL YOUR MONEY......................ROCK....
[email protected]
