Alright resident experts. I have a MM210 and need a setup for welding some 16ga. square tubing. What wire, flow rate, wire speed and tap setting?
set-up for 16ga. tubing?
Tags: None
Todd, Miller's calculator shows for C-25 and .035 wire:
17-18 volts/90-110 amps/180-220 wire speed
.030 wire:
17-18 volts/90-110 amps/220-250 wire speed.
Don't have a 210, so I can't tell you which tap, but I believe either the panel settings or owner's manual settings will tell you which tap coincides with what I gave you. You need to order the $25 educational student kit from Miller . Many books, all their slide rule calculators and a certificate for a free Miller jacket w/ proof of purchase of your 210. I know it gets cold enough in Meridian for a jacket.
I was thinking of using .023 wire with a tap setting of one and speed at about 28
Srubrn,
Your owner's manual on page 21 has a nice chart to use as a general starting point for parameter setting. For 16guage metal, .023 wire, and straight CO2, try Voltage=3, Wire=45, flow=25CFH. For a 75/25 gas blend, try Voltage=2, Wire=40, same flow rate.
Did you get an owner's manual when you bought the MM210?
-dseman
Originally posted by dseman
Srubrn,
-dseman
Cope
In most cases for the short arc settings given on the Millermatic calculator for 16 ga - 3/8" if you actually go down one material thickness on the settings you end up with better results. For example, if your going to be welding 1/8" with an .035 wire and C25 use the 14 ga settings. Which are 17-18 volts and 240-260 IPM (120-130 amps). The short arc settings given on the calcuator are a little hot in this range because they are production settings, where speed is important.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
I did get manual and have looked at it, but I just wanted some real world settings. Thanks for all the help.
Originally posted by Dan
Cope
I just did some work on a new exhaust system for my street/strip car. The tubing was 3 1/2" and 3" aluminized 16 ga. steel tubing.
I found that the aluminized tubing rquired a hotter machine setting to burn through the coating...still didn't weld terribly great.
If you have plain steel tubing, you'll have a pretty easy time welding. The aluminized takes some getting used to.
BTW, I was using a MM251.
Subrn,
In a real world setting using 75/25 mixed gas and .023 wire welding on mild steel square tubing with wall thickness of 16ga., set your voltage to 2 and the wire feed speed to 40. Now things that will change these settings will be your actual input voltage. These settings are for a 230v primary input on a dedicated 230v, 30amp breakered circuit. If your actual input voltage is measured higher than 230 volts the settings may need to be lowered a bit. If your actual measured input voltage is lower than 230 volts you may need to raise the settings.
MikeG
I grind the area of aluminized tubing before I weld it. Welds much cleaner. I use 90/10 gasMy politically correct no advertising/no ethnicity bashing/no shoving my religious(or lack thereof) beliefs down your throat moderator approved signature. For further info on making your own sig, subscribe to my secret yahpp gropu with over 300 members for $9.95
I do have a HH 135 that has .023 wire in it and I could use it but I wanted to use my MM 210.
