I want a pipe and tubing bender that I would mostly use with 3/4" square and round tubing. Also I would probably use it to make 90 degree bends in material up to 3/16". What would be the best bargain? Price does not necessary make something the best bargain. I want a quality unit without spending too much money.
Pipe bender, one more time!!!
Tags: None
The shop outfitter looks like it would do the most for the buck.
My Dad got us geared benders must have been over 30 years ago for 1/2 to 1.
They work ok, but they do take time to get used to, I replace the handles with a rachet assembly from an older Ridge Pipe threader.
I have seen the same bender on E Bay for around 35.00 I was going to bid on one for spare parts.
Good Luck
Bernie
Re: Pipe bender, one more time!!!
- jack
there are alot of different priced options for bending tube depending on what you're trying to build
www.jd2.com - about $250 for the bender and $200 PER die
http://www.pro-tools.com/mb105.htm - about same price as JD2
http://www.tubeshark.com/ - lots o dollars
hydraulic jack powered benders (there are several variations of this design out there):
http://www.toolsplus1.com/eztube.htm - these aluminum dies have been questioned before on other forums as to their strength - though you get alot for the price (since you get 4 dies with the bender)
or you could make one yourself:
there are ALL kinds of benders out there but this is a start.
good luck.
- jackLast edited by morpheus; 04-28-2003, 04:30 PM.
I would recommend the Hossfeld number 2 bend. They have hundreds of dies to bend just about anything. Like tube, pipe, angle iron and a lot more. Not really cheap but extremely versatale. You might be able to get a good deal on one on Ebay.Art is dangerous!
www.PiedmontIronworks.com
Well, there is a good alternative. Harbor Freight sells a unit for $139, on sell for next two weeks (until May 12) for $69.99, looks identical to the Hossfeld unit. It will bend all kinds of metal, rods, tubes, pipe, etc. Metal scrollers use it for wrought iron work. Also, they sell a hydralic tube/pipe bender with several dies, operated manually, for $30.00 (uses a small bottle jack).Uncle Dannie
Hobart Handler 135
Jack, I have most of the parts to a hossfeld bender number 2. I bought it on ebay for $300 from a retiring horseshoer. It is about 45 years old. I need to find some time to take it a part and get it powder coated. I also need to buy some dies for it.
Dan, The HF unit might look like a hossfeld number 1 unit from a distance. The Hossfeld number 2 will do all of the heavy stuff. I would not try to bend any pipe or tube on a HF unit. You don't get the dies for it. Their hydraulic unit is a pipe bender. I have heard that it kinks tubing. Pipe is thicker stuff.
ChadArt is dangerous!
Mike
