galvanized stick?
  • galvanized stick?
    I have just bought a stick welder as have been using migs for years. Bought the stick as heavier farm and truck things to do. My question is:. When welding galvanized, what type electrode should be used?
    I will Thank you in advance!
    Tony
    Need to know how thick of stuff your working on here. If its thick I would say 6011 that will burn hot and burn throught that coating. your better off to grind off that coating and go with a 6013 or 7018. That coating can be nasty stuff when its buring or grinding off. make sure you have a LOT of fresh air at all times!
    Watch that 7018 it needs to be kept dry and in a rod oven.
    Thats just my thoughts thoe.
    OMS
    OMS
    HH175
    Red Tomstone W/ HF for TIG
    Smith O/A X 2
    Harris O/A
    BridgePort
    MSC cut off BandSaw 6X12"
    And more!
    Shop Mechanic for Brinks Coin
      Hello OMS, you were right on with the E6011 or E6010. Use a whipping technique, this will help to volatize the coating in front of your weld. Do a search on this topic, I know last year I gave a lengthy answer on this.
      Respectfully,
      Mike Sherman
      Shermans Welding
        HI there mike. Been thinking of heading out one moring and see that new toy ( opps bikes are NEVER toys ) of yours But its been pretty nice out and thought you might have been out test riding it !!!
        OMS
        OMS
        HH175
        Smith O/A X 2
        Harris O/A
        BridgePort
        And more!
          I've been working mostly. This last weekend (Easter) I worked the whole thing, finally got the scooter out on Sunday evening about 6pm.
          Respectfully,
          Mike Sherman
          Shermans Welding
