I have an opportunity to purchase a Hobart Ultraweld 130- cheap, used and in fair to good condition. Is it worth purchasing? Any idea of age or value? Seller doesn't know much. It supposedly uses 115V or 230V. I have 230 Volt in my garage, that I use for my MIG.
Hobart Ultraweld 130- What is it?
Originally posted by ContecoBut what is Lift TIG? I've heard of, but not used TIG, and never heard if Lift TIG.
Originally posted by Hobart Expert KeithConteco,
The UW130 was a unit that Hobart Bros Co. sold in the late 80's. It is a 130A output/230Vac input and 75A/115Vac. It is has DC output only but can do stick and Lift TIG. It is built with inverter technology.
Hope that helps.
KeithRegards, George
Ultra Weld 130- What is it?
Thanks! With DC output, using lift TIG, I couldn't do .100" aluminum, though, could I? Also I didn't dee a gas feed on the unit. Maybee I didn't see, the gas port. Wouldn I also have to purshase a tungsten power tip? Sorry for so many questions, but the seller doesn't know.
Originally posted by ContecoThanks! With DC output, using lift TIG, I couldn't do .100" aluminum, though, could I? Also I didn't dee a gas feed on the unit. Maybee I didn't see, the gas port. Wouldn I also have to purshase a tungsten power tip? Sorry for so many questions, but the seller doesn't know.Regards, George
Knowing from where you "picked it up" and what you were told about it gives us a significant head start. You need to be qualified to stick electrical meter probes inside the machine while it's powered up. Otherwise, it may be worth bringing it to a qualified person.
Is there a switch inside to select the input voltage?Last edited by MAC702; 08-27-2021, 08:36 AM.
I picked it up for free from a stranger who said he had seen it weld a long time ago, and it's been sitting for years. (The rod holder alone is worth more than what it cost me to go pick it up so I'm not out much either way)
There is a switch inside, labeled "115" on one side and "320" on the other. It is set to 115.
I have no issue probing around but without a wiring diagram (and no understanding of how an inverter welder actually works) I won't know what I'm looking for.
I did find a small fuse on one board which I removed, tested, and reinstalled.
It would be awesome to find an owners manual for it.
- Likes 1
This is what the fave of the machine looks like. Now most of my stick welding experience is on a Miller thunderbolt XL AC/DC. I'm not super familiar with having adjustable arc force and hot start. (Which is what intrigued me with this machine, just something to play around with at home). Would you happen to know what the two indicator lights mean? (Neither come on)1 Photo
Update, I made new cables and picked up some fresh rod just to rule out possibilities. Still no weld. Hooked up my voltmeter to the leads, and I get 17V. That seems quite low. I would like to find out what I need to do to run it on 220, and what to maybe check inside, common culprits in this type of equipment, etc.
