portable ? for ROCK
  • portable ? for ROCK
    hello rock. on my gc350 i tested voltage like u said. it stayed at 48-50.i found a blown fuse in the right side circuit board. not sure what it is as ive not found a manual yet. went to local shop and they gave me a # of repairman. tried again today and could not get a stable arc at any amp. starts and then stops right away. it relites just as fast as it quites???? i,ll see what this repairman says and see if i can get a new fuse. thanks darryll
    BARTH...........IF YOU LOOK AT THE FUSES AGAIN THEIR ARE 6 IN THE CIRCUIT. THEY ARE YOUR CLOCKING WINDING COMMING OUT OF THE STATOR HOUSEING............. 34 TO 36 AC VOLTS ACROSS EACH PAIR. TOP 2, MIDDLE 2, AND BOTTOM 2...........
    ALSO IF YOU CALL BUFFALO WELDING SUPPLY AND SPEAK TO AMANDA WITH THE SPECIFICATION NUMBER SHE CAN GET YOU A MANUAL.........HER NUMBER IS 716-875-3472 AND TELL HER THANKS FOR THE HAT............................ ..............ROCK [email protected]
