Hi all,
New to the group so be gentle
. Pleased to have found this forum since I’ve already gathered a lot of useful info and the tone of the participants is first rate (polite, respectful, and helpful). Now to the questions.
Diodes on my HH120 seem to be bad, both have continuity in both directions.
Do these go out fairly regularly? (not per machine, but for the entire HH120 population)
What usually causes it, just age and heat?
Could a poor external supply circuit (15amp) cause it?
If one goes bad will it usually take out the other one?
When replacing the diodes would it make sense to replace the capacitors that are attached to them (C2, 3 from the wiring diagram)?
If one of those capacitors was poorly attached (soldered) could it kill the diode? I wouldn’t think so given its apparent purpose, but what do I know.
Are there any significant reasons I should use OEM “Hobart” diodes as replacements given that the welder is out of warranty? I know the diodes are 70 amp, 200 volt, but I’m not sure about their “speed” (i.e., fast, ultra fast, etc.). Wouldn’t a diode like this (see link) work just as well? Or are there other specs to consider (which ones? I like to learn)? http://www.surplussales.com/Semicond.../Diodes-3.html (the upper left one)
I don’t have anything against supporting Hobart, but I imagine I might have less trouble finding “equivalent” diodes in stock at an electronics supply house than at a welding center, I’m assuming they wouldn’t have them in stock and imagine it could take awhile to get them. Besides, I like to have options/choices. Anyone have experience with getting parts for this unit? Guessing cost would be $10-15 each, ballpark?
Guess that’s enough for now. Thanks in advance for all thoughts, advice, insights, it’s greatly appreciated.
Don
If I’m not learning I must be dead....or might as well be.
Don
