Hey guys im new to this forum im Bill. I got a questino for you guys . im goning to be blunt , what do i need to jump to the next level,duh let me tell you what i have, I have a miller ac/dc buzz boxs, victor st900fc cutting , metabo grinder ,sawzall, hand drill, vise , anvil, forge and my favorite about 100 sheets of 1/4 through 1 inch steel ( a little over 2 by 4 feet)
What do i need
WildBill,
This is an easy question to answer. It depends on what you want to do/make............
................lathe, mill, brake, plasma cutter, benders......larger work area...........
Dave"Some days you're the dog, some days you're the fire hydrant"
well at the moment in time im doing light fabrication for my self( jeep stuff , balcksmithing stuff and general repairs) and friends, i have acsess to a lathe, mill and brake but very rairly need them . it just seems i need to boost my productivitymm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
just an other traveling man pennmorris 778
A MM 251 or MM 210, metal cutting bandsaw, and a drill press would make a good start towards the next level.MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
my local retool has an atlas power hacksaw for about 100 or a peice of junk vert bandsaw for for about 200 would the hacksaw would it be worth it or just wait for a good band, i also have found a nice old delta drill press but i think they are asking 600 so i might just buy a jet or newer delta what do you guys think , how much would a miller 210 or 251 run me??mm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
youll never guess how i move the steel i have an old snowmobile jack the has two skid that are about 2 feet apart and 3 feet long and it wheels the steel around reall nice and i can raise and lower as a temporay welding bench.mm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
The MM 251 can be a budget buster at around $1700. Scott gave you a pretty close price on what a MM 210 goes for around here in Oregon. For the price though the MM 210 is a very nice machine.
A power Hacksaw is kinda slow, but much better then manual labor. You can get a good new 4" X 6" metal cutting for $250 or less, which cuts alot quicker then a power hacksaw. However, I prefer my 7" X 12" Jet. A new 7 x 12 usually sells for $850 to $900MigMaster 250- Smooth arc with a good touch of softness to it. Good weld puddle wetout. Light spatter producer.
my budget right now is about 2500( just sold some jeep parts) but anyways i just got thinking would it realy be nescary to bump up tothe 251 since i have the stick machine is there any real adavatage , also just looked in harbor freight and they had a vert bandsaw in that price range are theres any good??mm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
I agree, if you are doing much welding at all you need a wire feed. Way faster and way easier for small parts too. If you are welding lots of bigger heavier joints all the time you would like the 251 machine better. If you had to you could o to .045 wire even. For maintance and repairs that 210 looks like a great deal and should handle .035 well.
well i think tommrow im going down to the welding store and going to look at the mm 251 thanks alot guys, any suggestions on gas mixsturesmm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
My soon to be wife told me to thank you guys she said im might be able to put the cataglogs down tonight. you guys have me convnced on the mm 251 i think and ill def look into a band sawmm210,dial arc, xmt cc,lincoln 300d, ahead le and victor torches( no plasma yet)
Wild Bill, see if your dealer still has any Miller Vintage machines left or can get you one. They were in the 2002 catalog but dropped in 2003. I have heard nothing but good about them. Look on Miller's site under owner's manuals for more info.
