I have recently bought a mig man 150 and I am looking for a product manual for it. There is one promlem as the serial number is unreadable.One reason I am after a manual is the welder is shutting down after a few minutes of welding , so I am trying to find out what might be causing the problem,as it is very annoying when it does this.
mig mate 150
DARRYL..............WOULD THAT BE A MILLERMATIC 150 YOUR REFERING TO.............IF SO I CAN HELP, GIVE ME A LITTLE MORE INFO I CAN PROABABLY STILL HELP EVEN IF IT IS THE COMPETITION'S...................BY THE WAY..... WELCOME ABOARD.....................ROCK
[email protected]
Migmate 150
Darryl,
Does this unit need a separate feeder or is it built into the unit?
We bulit a unit called Migmate 150 back in the early 1980's that used a separate feeder. As soon as we identify this thing I will be able answer any questions you have and also can get you a manual.
Kevin
[email protected]
[email protected]
Mig Man RC150 and not a Mig Mate 150 that I stated in my first message, (my apologies for that) but I have been making so many enquiries about the welder and mig mate was mentioned and it stuck in my head.
Regards Darryl.
GOODMORNING DARRYL...........WELL IF IT IS A MIGMAN THE SPECIFICATION NUMBER IS 6331-1.........HOWEVER I DO NOT RECALL THEM BEING RC-150'S...........ANY CHANCE I CAN GET THE SERIAL NUMBER FOR IT OFF OF YOU..................THAT WILL PIN IT DOWN.................KEVIN SAID YOU WERE FROM DOWN UNDER..........SPENT SOME TIME IN YOUR COUNTRY WHILE DOING A STINT IN THE MILITARY..............ALSO IN NEW ZEALAND........AND THE SOUTH POLE [email protected] ELECTRIC SAID YOUR IN QUEENSLAND..........................?............. .........NICE COUNTRY.....................ROCK..................
S[email protected]
[email protected]
GOODMORNING DARRYL...........WELL HERE IS THE PROBLEM IF I GUESS AND SEND THE 6331-1 LIKE I'VE ALREADY SUGGESTED.........IT IS FOR A 200 AMP MACHINE WILL NOT WORK FOR THE RC-150.............AND THEIR IS ONE OTHER PROBLEM WOULD YOUR MACHINE BE 50 OR 60 HZ.............IN ALL HONESTY YOUR MACHINE IS QUITE OLD..........AND THE ORIGINAL MIGMAN WAS AN IMPORT AND THE COMPANY IS NO LONGER IN BUSINESS.....THIS IS YOUR CALL...........IF WE GUESS AND SEND YOU A RC-200 MANUAL WHICH IS A 6331-1 IT WILL COST YOU $15.00 USA FUNDS..............AND IT WON'T BE CORRECT........ LET'S TRY PLAN B UNPLUG THE MACHINE AND SEE IF THEIR IS A SERIAL NUMBER INSIDE THE UNIT UNDER THE SHEET METAL........... YOUR CALL..............AFTER ALL IT IS YOUR MONEY.............ROCK
[email protected]
DARRYL.........THE ORIGINAL SPECIFICATION NUMBER TO THE FIRST MIGMAN WAS 6610-1. IT WAS AN IMPORT FROM MEGATRONICS AND IT WAS 120/230 VOLTS. 90 AMPS, 20% DUTY CYCLE, OCV WAS 31 VOLTS WELDING VOLTAGE WAS 19 VOLTS. LENGTH 28 INCH'S, WIDTH 10 3/4 INCH'S, HEIGHT 15 INCH'S WEIGHT 96 LBS................ I STILL DO NOT WANT TO GUESS AND JUST SEND YOU A MANUAL...........................NOW YOU KNOW THE LENGTH, WIDTH, HEIGHT, AND WEIGHT.............IS THIS IT........ROCK
[email protected]
